What injectors? - LS1TECH - Camaro and Firebird Forum Discussion
Notices
What injectors?
Old 10-29-2018, 11:18 AM
Default What injectors?
I have a Iron block 6.0 that has been bored and strocked to a 6.2.
It has GM ported LS 3 head, LS3 intake and LS3 injectors.
The cam specs are: 227 INT 235 EXT DUR @.050 lift
613 INT 620 EXT Lift and 113.0 Lobe Sep.
Should I change to a different injector, or ?
I presently have a 80mm throttle body, but am thinking about getting something bigger.
Thanks,
Rob
rll2 is offline
Old 10-29-2018, 05:00 PM
AUS Injection's Avatar
How much Horsepower are you pushing?
AUS Injection is offline
Old 11-03-2018, 02:08 PM
410 to the wheels
rll2 is offline
Old 11-04-2018, 01:30 PM
LS1Tech Sponsor
Default INJ-60 650cc Flow Matched
Hi, I supplied Jacob (Darth8) a set of INJ-60 fuel injectors (Flow Matched with Dead Time Reports) that preformed BETTER than the smaller ones he replaced.
Read that report Darth V-8's thread.
I can supply the same for your needs.
Lance Pantera EFI 949-250-1797
pantera_efi is offline
Old 11-06-2018, 12:38 PM
LS3 injectors are 36lbs @3bar, you should be fine at 410HP, unless you plan on pushing more later on.
Old 11-06-2018, 05:32 PM
Kfxguy's Avatar
Stock ls2 or Ls3 injectors will support that hp.
Kfxguy is online now
Old 11-15-2018, 10:27 AM
Maybe I'm barking up the wrong tree.
I'm looking at what bolt-ons I can change to pick-up a little horse power.
If I replace my throttle body with say a 102mm and a different set of injectors, will that work?
Or should I keep the LS3 injectors even with the larger throttle body?
Thanks,
Rob
rll2 is offline
Old 11-15-2018, 12:00 PM
Which exhaust system do you have?
G Atsma is offline
Old 11-15-2018, 03:43 PM
bttlfed lss10's Avatar
Stock ls3 injectors will be fine even if you replace the throttle body. The throttle body will be a very small gain if any most likely.
bttlfed lss10 is offline
Old 11-15-2018, 04:31 PM
handyandy496's Avatar
Put a big mouth 92 on it for the throttle response and a couple of horses. Injectors will be perfect. I bet you will be at 80% duty cycle with the big mouth and gmpp heads being a stroked 6.2. Your pistons will be moving a lot faster. 420 is low for that short block and what you have. I picked up 5 mph in the 1/8 with a real good y pipe 3 into 4" with a dump in the 4" section. That's 50 hp son.
handyandy496 is offline
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
