Notices
New fuel rails, now won't run
Old 11-09-2018, 10:16 PM
2010Imperial's Avatar
Originally Posted by qweedqwag View Post
Pull the plugs and see it she turns over.
I pulled the plugs a couple days ago. She won't budge. Even trying to turn it by hand... FROZE
I also disconnected the battery and let it set over nite…..
2010Imperial is offline
Old 11-09-2018, 11:13 PM
Tear-down time.....
G Atsma is online now
Old 11-09-2018, 11:17 PM
This is BS. How can I go from a perfectly running engine, to a locked up engine, just from doing a simple fuel rail swap???????????
Old 11-09-2018, 11:23 PM
Just a guess, but debris in new fuel rails got in an injector and caused an injector to stick open and hydrolock the engine. Does oil have a fuel smell to it? I would pull the injectors and test with a 9v battery to make sure they are all working.
Longblue is offline
Old 11-09-2018, 11:31 PM
I said it earlier; it might be a coincidence. OR it could be hydro-lock. Either way, pull the heads and see what is going on, rather than persist trying to turn over a stuck engine. Speculation can go on forever....
Old 11-10-2018, 07:22 PM
Or something fell into the intake through one of the injector holes and now has a valve jammed open etc.
RockinWs6 is offline
Old 11-10-2018, 08:18 PM
Hopefully I can start tearing it down tomorrow night. And I am praying, whatever damage there might be, is limited to the top end. We will see.....
Old 11-14-2018, 04:12 PM
I have only had time to take the intake off. So far nothing suspicious. Heads are next. So if I am going that far, guess it's time for a cam/heads combo! Any suggestions? I've always said I would get a GPI cam and keep the VVT stuff...
Old 11-15-2018, 10:29 AM
AUS Injection's Avatar
Before you go any farther, have your injectors checked to see if they're are clogged or stuck open from fuel rail debris. it would suck to tear down your motor and just find out it was debris in the injectors. LMK pm
AUS Injection is online now
Old 11-15-2018, 11:02 AM
The engine is locked up. Hydraulic lock would only do that until it drains off. He has mechanical issues.
Old 11-15-2018, 11:05 AM
Gotcha, but regardless those injectors should get cleaned. Time and time again we always see customers with clogged injectors from using a brand new fuel rail. Hope you get it figured out and get her on the road again!
Old 11-15-2018, 11:11 AM
  #32
Good points! I too hope he gets it going.
Old 11-15-2018, 08:30 PM
  #33
Tomorrow the heads come off. Just double checking that I can safely rule out any computer BS being the problem? I don't want to have to buy new gaskets and bolts to find that out... Thanks for the well wishes!
Old 11-16-2018, 09:41 PM
  #34
I didn't get to the heads, raking leaves was a higher priority. But, I did notice when I took the intake off, there were some "pebbles" rattling around in there. Not to sure what they were when they fell out. I know there shouldn't be any thing like that rattling around in there, but anything is possible at this point!
Old 11-16-2018, 09:50 PM
  #35
Did you save them? Are they metallic?
Old 11-17-2018, 07:42 PM
  #36
No. I had the music cranked up and didn't notice it until pretty much they fell out. No telling what they were. So now I am stuck on one stripped header bolt. Everything else is apart and ready for the big reveal. I hope I see something.....
Old 11-18-2018, 01:05 PM
  #37
Did you look or remove the mechanical fuel pump under the manifold to see if the drive mechanism for it failed?
dlandsvZ28 is offline
Old 11-18-2018, 04:21 PM
  #38
Which mechanical pump? This is a Gen IV, not a Gen V. Gen IV's don't have a mechanical pump.
Old 11-19-2018, 12:27 PM
  #39
Restricted User
There is no middle, or end to this story.
There is certainly a moral to the story, and a reason I still run factory rails on all of my setups.
JoeNova is online now
Old 11-19-2018, 07:46 PM
  #40
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
