Any point to larger fuel lines if running a Flex Fuel sensor? - LS1TECH - Camaro and Firebird Forum Discussion
Go Back  LS1TECH - Camaro and Firebird Forum Discussion > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Fueling & Injection
Reload this Page >
Notices
Old 11-16-2018, 05:43 PM
FCar2000TA's Avatar
Default Any point to larger fuel lines if running a Flex Fuel sensor?
Sorry if this is a stupid question, but since the GM Flex Fuel sensor tube is 3/8" in diameter, is there any point in having fuel lines larger than 3/8"? Seems like the sensor would be a bottleneck if the lines are larger.
FCar2000TA is offline
Old 11-16-2018, 06:22 PM
Not really....
G Atsma is online now
Old 11-16-2018, 08:42 PM
Restricted User
You can split the line into 2 separate lines using Y fittings and put the flex sensor on only one of them.
JoeNova is offline
Old 11-17-2018, 08:26 AM
01ssreda4's Avatar
Or put it on the return line?
01ssreda4 is offline
Old 11-18-2018, 11:08 AM
FCar2000TA's Avatar
I will probably put the sensor between the regulator and fuel rail. That will make it an easy upgrade if/when a 1/2" flex fuel sensor comes out.
Old 11-19-2018, 07:42 PM
There are other bottlenecks that are 3/8" in the system in the fuel tank/pump area but people still run 1/2" line from the tank to the rails. I believe a system that is entirely 3/8" will not flow as well as a system that is 1/2" and has some small 3/8" bottlenecks, but I'm not a PHD in fluid dynamics... I would still run 1/2" lines if you are using more than 450LPH to reduce pressure drop from the pump to the rails.
89mulletbird is offline
Old 11-20-2018, 09:03 PM
Crf450r420's Avatar
I'm running the stock 3/8" hard line and used the 5/16" vapor line as the return. Since I wasn't sure if this would change the set pressure with a 450lph pump. I first set it up with the return into a fuel jug where I set the pressure to 43 psi. I then connected the return through the 5/16" hard line back to the tank and the pressure stayed the same. Use open swept fittings and you can run far more than most think. I will put a pressure gauge back by the filter soon just to check the pressure there, but I doubt it's much more.
Crf450r420 is offline
Old 11-20-2018, 11:03 PM
FCar2000TA's Avatar
I am getting the CHRS1313 dual 450 kit with -8 feed, -8 return, and stock vapor. I am going to be using a fuel filter that is -8 in and out, And the regulator has -8 connections. Everything from the fuel in the tank to the regulator output should be at least 1/2".
Old 11-21-2018, 07:40 AM
Restricted User
With dual 450s, I would probably Y around the flex sensor. With a single, there isn't any need since the stock fuel line sizes are able to handle the single pump.
JoeNova is offline
Old 11-22-2018, 11:43 AM
Crf450r420's Avatar
I can hear the fuel moving a little to fast in my 5/16 return, but it's not a critical point so I'm not worried about it, but for dual 450 pumps, I would certainly run 1/2" and I'm the guy normally saying people use to much hose.
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
