Biggest fuel pump that doesn't overpower Vette regulator/filter
Old 11-29-2018, 08:39 PM
Kfxguy's Avatar
I went with an aeromotive pump because:
1) they are known to be high quality and reliable
2) my buddy was running one for quite a while on his head/cam gto and no issues
3) I read multiple tests where the aeromotive beat pretty much all the other pumps and weee more consistent
Old 11-29-2018, 08:42 PM
LS1Tech Premium Sponsor
tech@WS6store's Avatar
We have had much better luck with the racetronix. They are literally a fully engineered setup from start to finish with a hotwire harness and nearly all are plug and play. Simple and easy. With much better components and options.
The aeromotive stealth 340 pumps we had issues on and alot of customers did also
Most of the issues with racetronix pumps are actually either improper install or a bad charging system.
Old 11-29-2018, 08:53 PM
Kfxguy's Avatar
i dont doubt what you say. Maybe I’ll check into racetronix for my next round of mods coming up. I’m probably gonna need dual pumps. Or I thought about just doing a boost a pump for simplicity.
Either way, we have options!
Old 11-30-2018, 08:08 AM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
WS6store is on point. Basically typed exactly what I was thinking.
Old 12-01-2018, 09:41 PM
94LS1B4C's Avatar
Just to share my experience. Back in July, I ordered the racetronix 340 and hotwire kit from the ws6 store. About 3 weeks ago the pump failed. I'm in the process to figure out why. I am running a corvette style fpr/filter.
Old 12-01-2018, 10:04 PM
Kfxguy's Avatar
O. Well that’s good to know. Makes me feel better about my crappy aeromotive.
Old 12-02-2018, 12:52 AM
foxsl's Avatar
Perhaps the more restrictive the return line is back into the tank, the more fuel gets backed up at the regulator, the regulator then gets overpowered, resulting in higher fuel pressure that is hard on the pump and kills them. I guess you Fbody and c5 vette guys have a 5/16" return line. The vette filter/regulator has a 5/16" return line if I remember right.
My mustang had a 1/4" return line in the fuel tank hat from factory, scary stuff. I currently have a new hat with a -6AN return and feed. So maybe it would accept a larger than 255 lph fuel pump and still maintain a reasonable fuel pressure around 58 psi. Just assuming I'd be better off as I also have -6AN line from the fuel tank hat return fitting to the vette filter but it does go into a -6AN to 5/16" at the regulator.
Old 12-02-2018, 01:38 AM
Normally early failure is related to low voltage or current to the pump.
Not higher pressure.
We will be happy to replace the pump. But make sure to check your charging system, connections, and battery. I normally recommend the truck alternator also or at least the HD pigtail upgrade.
Old 12-02-2018, 12:01 PM
94LS1B4C's Avatar
I was on the stock pump for 96,000 miles. 5 of those years was on e85 and at the time of pulling the pump it was still operational. During the racetronix pump and hotwire install along with the vette regulator/filter I also replace the battery and upgraded the alternator to a truck alt. I was running 6an return and 8an feed.
Old 12-02-2018, 06:04 PM
Call us up tomorrow
Old 12-03-2018, 08:58 PM
  #32
94LS1B4C's Avatar
Call us up tomorrow
I called today around 3pm and left you a message. I spoke with Mike.
Old 12-05-2018, 12:47 PM
  #33
peterskunk's Avatar
i sent you a PM regarding this, thanks!!
Old 12-10-2018, 10:23 AM
  #34
"I MAID THEESE"
Mavn's Avatar
I run a Wally 450 with harness with my stock intake regulator and its 58psi at idle. my regulator is just good I guess lol idk
Old 12-10-2018, 10:34 AM
  #35
ddnspider's Avatar
No way. You logging it? Hard to believe it wouldn't raise FP.
Old 12-10-2018, 11:24 AM
  #36
"I MAID THEESE"
Mavn's Avatar
I have a gauge on the rail. and just for ***** n giggles we checked it with another one . both read 58 lol
Old 12-10-2018, 11:58 AM
  #37
ddnspider's Avatar
That's some craziness. Even my 340 would increase rail pressure.
Old 12-10-2018, 12:04 PM
  #38
"I MAID THEESE"
Mavn's Avatar
I know, right.. every one ive done on other cars raised it to around 70
Old 12-10-2018, 08:34 PM
  #39
Not all 450s are the same...plus they are only 340 to 360 at 58psi and 13.5v. Most arent actually graphed that arent name brand. Theyll just copy a graph from another place. Ask me how i know.
Old 12-11-2018, 04:41 PM
  #40
"I MAID THEESE"
Mavn's Avatar
Genuine TI automotive 450 here. No ebay junk.
