Notices
Biggest fuel pump that doesn't overpower Vette regulator/filter
Old 04-10-2019, 12:54 PM
  #61
The Corvette regulator regulates to 58psi. You don't "tune" a regulator like this. It's a very simple component.
G Atsma is online now
Old 04-10-2019, 02:14 PM
  #62
LS1Tech Premium Sponsor
Only vacuum referenced regulators use a "flat" ifr.
The rest have to be scaled.
tech@WS6store is offline
Old 04-10-2019, 03:31 PM
  #63
[email protected], after reading this I believe I'll be calling tomorrow to order pump/hot wire kit/Vette regulator for my thirsty f body.
Kjduvall is offline
Old 04-10-2019, 07:36 PM
  #64
brandon6.0's Avatar
All i needed to know. Thanks.
brandon6.0 is offline
Old 04-10-2019, 09:57 PM
  #65
Sounds good!!
Old 04-10-2019, 11:42 PM
  #66
Thank you for the reply !!
P31Jeff is offline
Old 04-15-2019, 09:16 AM
  #67
TT427's Avatar
Not intending to hijack here learned alot, Wondering about the upgraded bulkhead for the 98, and what FPR you would use for a 98 boosted app w/7875 turbo 80lb Dekas. I got the RaceTronix 255 and hotwire kit about a year ago before i got the turbo kit and have not installed it yet, got the Huron Seed kit on now and honestly would like to do a 1 and done pump deal if possible since the ls1 will come out soon. Swapping in a 6.0 or 5.3 as Im not interested in blowing it up (only 80 thousand on it) and it will go in my C3 Vette. IDC which pump and regulator an AEM 320/380/400 or Walbro 450 whatever will get me in the 700-800hp range will be all i intend on needing, that should be enough for 9 sec passes If I ever work up to that. I know the 255 will not get me there.
Should I just do a second pump at this point? Seems overkill and more complicated, The cost of the 255 pump at this point means nothing as far as simplicity and just beign done with it for the future since I will be dropping the tank not hacking a hole. Would gladly take a pm so as not to clog OP.
TT427 is offline
Old 04-22-2019, 01:57 PM
  #68
TT427's Avatar
Any thoughts on the DW300 with the C5 filter/regulator?
TT427 is offline
Old 04-23-2019, 03:23 AM
  #69
Guys, instead of just finding pumps with numbers in their names, look at their fuel curves and output vs volts/amps. Help yourselves make an informed decision.
Old 04-23-2019, 09:38 AM
  #70
TT427's Avatar
I did, I have looked at just about every relevant test/chart published from about 2011 or 2014 on. What do you think I just pull "numbers" out of the air? It appears to be the highest flowing "340" pump out there that stays under 14 amps @58psi. Just wondering how it would suit the Vette regulator/filter upgrade... Then i think why not just run a 380/400 in tank, a real regulator on the end of a good filter at the same position you put the C5 upgrade and run a real 3/8 return from there. Would maybe need to add an AN bulkhead to the lid... Seems like a pretty straight forward setup and could use the cheap racetronix regulator you have. You already have the the basis of the system in place, Im just wondering/exploring how it could be improved with a little more money and a little more effort. Especially since their is conflicting evidence of the Vette regulator truly being a problem solver...
TT427 is offline
Old 04-23-2019, 01:10 PM
  #71
LS1TECH Sponsor
Racetronix's Avatar
The Racetronix T-series pumps are the only HP pumps on the market which support the venturi / jet pump system in late-model fuel system modules.
If you run a DW, AM or any other brand you will have to hack your module and give up the functionality the factory engineers built into it.
All 3xx LPH pumps draw similar power. Our f-body wiring upgrade (FPWK-017W) provides support for up to 28 amps so +/- a few amps will not make a difference.
Bigger pumps are not better. They draw more power and put more heat into the fuel. Rule of thumb is to design a fuel system to support minimum 25% more than the motor requires for safety.
If your pump is on the ragged edge where you have to worry about a few LPH then it would be wise to consider a staged dual pump system over a single high-flow pump.
The C5 reg/filter is a simple inexpensive fix for the undersized regulator built into the factory module. Dedicated lines with a front-mount regulator and rails are better but those may not be in the budget or necessary for some customers.
Our regulator is inexpensive relative to some other brands who overcharge but they are high-quality parts.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Racetronix is offline
Old 04-23-2019, 04:05 PM
  #72
TT427's Avatar
I have a 98, don't want to get out of hand/overkill with dual pumps and cost of wiring, or the uncertainty of the C5 upgrade and possibly high pressure and short pump life, that's why I'm asking questions. My intention was not to hijack OP thread but at least further discussion relating to the C5 upgrade and higher output pumps. Saying that, I can only go by the fuel charts and test I can find. Nothing wrong with your pump and C5 upgrade but the dw300 in latest test I saw from Realstreet 2018 was about 45lph better than an AM/RT 340 pump and as far as I can tell the amp draw is almost an amp less @60psi going off your flow chart, DW flow chart and Realstreets test results.
TT427 is offline
Old 04-24-2019, 07:45 AM
  #73
How fast should the fuel gauge drop when you turn the car off. Mine drops right away, should it just bleed off slowly?
Tramminc is offline
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
