Hex driven Fuel pump on LS engine Hi guys! I'm building a twin turbo LS engine (iron block). I would like to use mechanical cam driven (hex driven, not belt) fuel pump. Is here anybody who already done that and could help me with some advice or some pictures? For instance, if I install the fuel pump on the timing cover, will that not interfere with the water pump, even if I use an electric water pump? https://www.yellowbullet.com/forum/i...milies/100.gif Is there any bolt on kit available on the market, with all the parts I need and some instructions? I was searching internet for information or pictures but did not find many useful stuff. Best regards! J. |
You'll have to use a remote mounted water pump if you want a cam driven fuel pump. I don't think anyone makes a kit for an LS. Usually easier to go belt driven. |
I'm 99% sure all will require you to run a remote water pump. https://joeblospeedshop.com/shop/jbl...th-cam-sensor/ |
© 2024 MH Sub I, LLC dba Internet Brands
