Corvette pressure regulator/ filter question Has anyone had a issue with these? I installed a Brand new AC Delco EP381 pump and one of the corvette reg/filter and im only getting 10lbs pressure to the rail!!! I can hear it bypassing and pushing fuel back into the tank. No its not in backwards...lol. Could it be bypassing and dumping to much back into the tank? |
If its real AC Delco, and it IS the Corvette filter, and NOT the s10 flex filter, then no. I have seen aftermarket ones do it, and then people hook up the S10 flex setup backwards because they are opposite of the Corvette filter. As far as the pump, since it is also stock, it should not bypass that much, as you know. I think its just bad. It sounds like you know your stuff on these. |
Originally Posted by rpturbo
(Post 20023853)
You're positive that you don't have them on the regulator backwards? The one in the middle is the return, not the feed. |
Originally Posted by JoeNova
(Post 20025776)
© 2024 MH Sub I, LLC dba Internet Brands
