converting FIC 127 lb bosch injectors I bought these injectors a while back. I originally intended to use them with with an ls6 intake. I have since changed to an ls3 intake so I need to use LS3 type injectors. It looks like they are EV6 injectors that were adapted to an LS! style. I can see how taking of the top hat helps but when I take off the bottom spacer it seems like the injector nozzle sticks out too far. If I leave the bottom on the fuel rail sits too high causing the injector to be crooked. Does anyone know what I am suppose to do? thanks https://cimg7.ibsrv.net/gimg/ls1tech...befad435e8.jpg |
Never mind. I just found this. Hopefully the extended tip does create any problems. https://ls1tech.com/forums/attachmen...rs-127line.jpg https://ls1tech.com/forums/fueling-i...injectors.html |
Great injector, you'll be pleased with them. They tune nice and Ive had no issues with my car sitting extended periods of time with E fuel in it. |
© 2024 MH Sub I, LLC dba Internet Brands
