Holley fuel rails brackets
Have a set of Holley fuel rails 534-210 to be exact we’ll switched to short style ls3 injectors and have to run the hats have to use the bracket with the bend in them but missing one now since I didn’t use them on last setup go figure and Holley doesn’t sell replacement
does anyone have them that I can buy from you ?
text me if you do can PayPal you asap
313-713-7435
313-713-7435
Just make one or however many you need. A thin piece of strap aluminum will bend easily in a vise. So if you have access to vise, a Crescent wrench, a drill and correct size bit you are good to go. A Crescent wrench works great when bending thin strap aluminum in a vise. You can buy a strip of aluminum at Lowes, Home Depot, etc.
Note: don't cut to length until you have the correct angle bend. Drill the holes. Then cut to length. It's lot easier to manage a piece that is five to 6 inches long rather than 1 inch.
Really don’t wanna hassle with making one right now rather try to find a replacement if I can have multiple other projects and builds going on and trying not to tie up everything to make this lol
