I'm ready to get yelled at. Help with FIC 1650
Trying to get the truck ready to turbo, I found a good deal on some cleaned and inspected fuel injector connection 1650s. I uploaded the data in there, and someone suggested cutting the minimum fuel milligrams in transient. Truck just idles pig rich. Its got a 4.8 with a 220/224 cam in it. Has rails with a fpr on it. PSI is set to 43.5. I just don't know where I'm going wrong. Truck had a solid tune in it on stock injectors, ve table was within 5%, no knock, good timing. Any help would be appreciated getting these fuel injectors lined out.
Your pressure should be at 58psi.
This video may help but you might have already done this.
So I have lowered and lowered and lowered the ve table. At these numbers it still idles at high 12s, and one number lower it jumps to 18 on the wideband........
Odd thing though is if I go lower on the minimum fuel than .007 in the transient tab it destabilizes. As in one bank goes rich about 7 percent and the other side lean about 10 percent which is funny because it makes my PID read about right lol. So, where do I go from here? I even tried raising my idle to 900 to see if I could get it to stabilize.
I just don't understand it because the STFT are able to lean it out to stoich, but I physically cannot command it to.
