Raw fuel coming out of tailpipes I HAVE A LS SWAP IN A MUSTANG THAT RAN FINE FOR A FEW YEARS AND OUT OF NOWHERE IT STARTED POURING RAW FUEL OUT OF MY EXHAUST.....Ive changed every sensor....regulator.....fuel pressure gauge Changed plugs.....checked injectors......dont know where else to check...even changed the pcm....could it be in the harness somewhere..maybe bad ground?? Any help will be appreciated.. THANKS IN ADVANCE |
I would guess a injector stuck open. How did you check them? |
Originally Posted by 98CayenneT/A
(Post 20088693)
Originally Posted by nos302
(Post 20088707)
With a noid...injector tester |
Ok thanks...ill try that |
(Post 20088707)
Originally Posted by Old Geezer
(Post 20088749)
That checks the electrical pulse activity, not the condition of the injs. Time for a flow bench test. |
Tonight i took all the plugs out again and spun the motor over......gas coming out of only one of the plugs.....seems like one of the injectors took a crap right after i had em checked .....go figure......ordered new ones....hopefully this was just some freak azz coincidence Thanks for all the responses.....let u all know how i made out once i install them |
^^^ Change the oil, before you start it, w/ the new injs. |
(Post 20089530)
© 2024 MH Sub I, LLC dba Internet Brands
