C5 fuel system help. Fuel line recommendations?
I have a 2001 C5 Corvette Z51 6 speed. I'm in the process of a Engine and Transmission Build. The whole car is scattered in the shop. I found that my fuel lines are nearly rubbed in half and I need to replace them. So might as well put a new fuel pump in and fuel lines while I'm at it. Current induction is Vararam,FAST 92mm Intake,90mm LS2 TB,FAST 46lb Injectors,Plan to buy FAST Fuel Rails also. Let me know what y'all think. Id like to run braided fuel lines.
Cheapest and safest Way also. Lol dont want any leaking issues. Street car.
Location: Coast of San Mateo County Between Pacifica & HMB
I had leaks with fast fuel rails, went back to stock ls2 or ls3 rails for a FAST LS3 Intake in my
99 C5 W/ factory lines and 340L pump W 60 LB injectors. 225/255 should be good for you NA to 500 RWHP.
