6.0 Rough Idle
6.0 Rough Idle
Need a little trouble shooting help.
My car was running perfect up until this past Sunday. I go to start it and its idling horribly. I had just driven it friday with no issues! I checked the plugs and they are all black with carbon build up so it's running rich.
I don't have any vacuum leaks that I can see, it has a speed density tune so the MAF is not the issue, has a brand new Coolant Temp Sensor. In fact, all the sensors are new outside of the MAP sensor as this is a recent swap in to my classic car.
I'm not getting any codes on my scanner.
The only thing I can think of is a fuel delivery issue. Maybe the regulator or pump are faulty? I have an external in-line pump installed.
I tried to start it again this morning and it will barely start now.
Any Ideas?
Any Ideas?
O2 sensors and/or MAF sensor, to start with.
@Old Geezer Going to grab a pressure gauge tomorrow. Hopefully I can get it to idle, won't even start now and if it does it cuts off.
It should pressurize with just the key on. 58psi is what you should get before it even starts.
