HP limit of stock fuel lines?
Old 10-07-2004, 11:40 PM
2001CamaroGuy's Avatar
Default HP limit of stock fuel lines?
Just to be safe I'm looking to make 500rwhp and then put a 250 direct port shot on top of that.
My fuel system is a return line style system that goes (starting at the tank):
- Walbro 255Liter pump
- stock supply line (I removed/plugged the "T" for the stock return setup)
- 97/98 vette fuel rail (adjustable pressure regulator on rail)
- stock sized (actually EVAP line) return line from rail
so it boils down "How much HP can a single Walbro 255 and a stock supply line support?"
If my system will not support what I'm looking to do, "Would sticking a second Walbro 255 in the tank help any or am I just limited by the stock supply line? How large should I go up to?"
thanks
Old 10-08-2004, 12:05 AM
MECHAM's Avatar
u will definitely need another pump
upgraded fuel rails would be nice too
BIGGER INJECTORS!!!
i have dual intank 255 pumps, rising rate regulator, fuel rails, 60# injectors
STOCK FUEL LINES
Quick Reply: HP limit of stock fuel lines?
