MSD Booster and racetronix harness
I have a couple of questions concerning installing the msd booster pump with the racetronix harness.
1. on the 1999 LS1 the MSD 30 amp relay connects to the original fuel pump relay. Wheres the original fuel pump relay?
2. when I connect the MSD Booster hot wire to the harness using the racetronix plug ins, does it bypass the redwire that once ran to battery?
LS1TECH Sponsor
Plug the MSD booster into the Racetronix harness. The input goes to relay end and output goes to the pump end. All - grounds on the MSD booster go to the chassis (ground).
The booster should be mounted close to relay underneath the car. If required a vacuum line should be run from a manifold pressure port to the MSD booster for voltage control.
Do not run the booster at the front of the car or tie it into the factory wiring.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
