How can I hook a A1000 to suck from a stock tank? I cant afford a 470 dollar tank, and i dont have the room for a cell. Any suggestions? THANKS! |
Buy a $60 sump and weld it in. Well, if you have a 98 that is. Otherwise you could swap it with a 98 tank then weld it in. |
I coulda told you that, you tard! haha yes sump a 98 metal tank and swap er in there. I coulda swore I saw someone use some bulkhead union fittings to sump a plastic tank, but I'd imagine that would leak. |
Why will it only work with a 98? the 98 is metal huh, why couldnt i get a few fittings like a chase nipple type thing(electrical part example) for it to work? |
You can use a bulkhead fitted to the top of your existing pump assembally. I've seen a few picks of that floating around. I opted for the sumped 98 model tank. Bought it in the for sale section for $100. |
Great guys thank you for the help! |
dont mean to hijack the thread but kevin clean out your pm's man.. ive been trying to email u and pm ya but not gotten anything to ya..thanks |
You can run a bulkhead in the bottom of the tank. It wont leak. A sump will be better though. Brad |
© 2024 MH Sub I, LLC dba Internet Brands
