Another Fuel System???
Old Jan 14, 2005 | 10:53 AM
BadCompanySS's Avatar
Philly Fakeout!
Default Another Fuel System???
Thinking about building a separate fuel system for my nitrous only. Has anyone done this? What pump did you use and what psi did it make?
Thanks!
Old Jan 15, 2005 | 05:05 AM
stevieturbo's Avatar
How much fuel pressure do you need, and how much fuel flow do you need ??
A 50 shot would have very diffferent requirements to a 500 shot.
Old Jan 15, 2005 | 10:44 AM
Green Thunder's Avatar
Thanks!
Early on, I used a holley projection pump with a Jazz fuel cell and a universal holley fuel pressure regualtor and it worked fine for a 260 shot..
There are a ton of fuel pumps that will work... You need to decide how much you plan to spray.... Do you want a high pressure fuel system or low pressure?? Keep it simple! You could just us a Holley BLUE pump that can be had just about anywhere... Just make sure your fuel pressure/jetting is correct..
Old Jan 16, 2005 | 11:57 AM
MOTRUBL's Avatar
I'm thinking of doing this also. I'm planning on running a 250 direct shot. I'm guessing it would go: fuel cell->pump->regulator->y block->solenoids->nozzles. The main question I'd have would be what fuel pressure should I run??
Old Jan 16, 2005 | 12:27 PM
Philly Fakeout!
I plan on a Jaz cell, Aeromotive Regulator and the pump I'm not sure of. Should I try to keep the pressure up at 59 or so like the jets are made for or sould I just get a pump and get the fuel jets to flow the numbers I want. Its going to be a 300 shot or so. I may split it up into a dual stage set up or something. I just can't decide on a pump.
Old Jan 17, 2005 | 09:28 AM
SDB's Avatar
SDB
Thanks!
APE (sponsor here) has a complete stand alone fuel system they sell and install....give them a call talk to Chris.
Old Jan 17, 2005 | 10:31 PM
Philly Fakeout!
bought a walbro high-pressure 255lph in-line pump. I have a 255 in the tank so I figured it should be similar. Now I just have to figure out where to mount the tank and pump.
