Stupid problem with in-line pump
Old Feb 22, 2005 | 01:30 PM
NOTFAST's Avatar
Default Stupid problem with in-line pump
Just put in the 255 inline pump....have fuel injection clamps on both ends but they don't seem like they are as tight as they can be..but when i tighten them more...it starts to leak...
so i figure i can put another clamp on each side, but when i do that and tighten the extra clamp, it starts to leak again...
im worried about a full WOT run and losing fuel pressure due to one of these clamps not holding
any thoughts? track opens on friday and i plan on running
Old Feb 23, 2005 | 09:49 AM
NOTFAST's Avatar
anyone got any ideas? I dont wanna run high pressure line from the tank to inline pump etc...
Old Feb 23, 2005 | 10:05 AM
EATAZ06MMM's Avatar
Are you sure you have the clamp in the right place? In other words, the clamp should be over the outlet nipple? Are they new hoses? Maybe your hoses need replacing......
Old Feb 23, 2005 | 11:33 AM
MIGHTYMOUSE's Avatar
try different style fittings / different style clamps
sounds like your hose is too big for the fitting and is bunching up on it
Old Feb 23, 2005 | 02:28 PM
GTS346's Avatar
Are u using the barbed fittings that come with the fuel pump?
Old Feb 23, 2005 | 04:35 PM
NOTFAST's Avatar
yeah, im using everything that came with the pump...cut the stock fuel line and put it over the barbs...then used a fuel injection system clamp...
