questions about rails and injector size First off I just got set of Billet fuel rails, anyone got instructions on connecting these including accessories to convert from stock fuel rails? Need some sort of crossover from one side to the other and how are the injectors held in place. The rails just look like an open hole for the injectors no real place to lock them in. Also, how are the rails held to the intake? Second, need to get a suggestion on injector size for my setup (383 stroker, 90mm intake, plan to run N2O in the near future) Any help or suggestions would be greatly appreciated!! Kody |
Nobody has any information to offer? |
30 lb svo's will be plenty for the engine and the n20 if you use a wet kit. You don't need the rails at your hp level....stock rails are good to 650rwhp. |
Originally Posted by onfire 30 lb svo's will be plenty for the engine and the n20 if you use a wet kit. You don't need the rails at your hp level....stock rails are good to 650rwhp. Thanks |
Yep, at 58psi svo 30's are 35's. Nastynate or Speedinc can set you up with the accessories to hook the rails up. Really depends on your choice of using a full return, the factory mini return, and a regulator or not. Give'em a call. |
Originally Posted by onfire Yep, at 58psi svo 30's are 35's. Nastynate or Speedinc can set you up with the accessories to hook the rails up. Really depends on your choice of using a full return, the factory mini return, and a regulator or not. Give'em a call. Thanks for the advice :thumb: |
We have a complete kit to hook your rails to the factory feed line with a solid compression fitting. Nate |
I use 42lb injectors,these are a very common size.It is what comes with a few of the major brand supercharger kits.By using this size you will also make it easier for your Tuner since they probably have a tune close to what you will need.I hope I am of some help.I have been considering a fuel rail upgrade but I have questions about if they are necessary.Good luck |
© 2024 MH Sub I, LLC dba Internet Brands
