The nexus fuel pressure gauge is pretty cool since it warns you when pressure is dropping off.. |
Originally Posted by HellRaiser you would have a good product there, if you came up with some kind of warning system. But either way( way you wire up the pump) without the warning I think you'll find out a pump is not working the hard way unless you watch your fuel pressure which I always kept a eye on. some simple logic that says: the fuel pressure is dropping.... BEFORE it drops to a really unsafe level. im thinking a fuel pressure sensor, a A/D converter, a PIC and a warning LED might work.... hmmmm |
How bout a hobbs switch set for a certain PSI. Connected supplying ground to an led or a light? |
My buddy has an oil pressure "safety switch" on his big block buick. At xx psi it kills the motor. I am wondering if there is anything like this that can be modified to work for fuel pressure? Andy |
Originally Posted by BlkHwk How bout a hobbs switch set for a certain PSI. Connected supplying ground to an led or a light? that would be the most basic safety system possible... but effective.. it wont tell you whats wrong, but you'll know to let out of it. id go one step further with that and have it trigger a self energizing relay... so that a momentary drop below that amount, would make the light stay on constantly until you reset it. although you'll then have to add some kind of arming or self-reset to it then.. otherwise it may come on during startup.
Originally Posted by White.Lightning My buddy has an oil pressure "safety switch" on his big block buick. At xx psi it kills the motor. I am wondering if there is anything like this that can be modified to work for fuel pressure? Andy |
© 2024 MH Sub I, LLC dba Internet Brands
