how far can u go on stock fuel system??
just got finished with my new cam swap in my 01' ss here is my current mods:
pp ls6 stage2 heads 66cc
cam 232/234 113lsa 595/598
stock short block
hooker lt's ,ory ,corsa catback
fast90/90 (ported)
meziere electric water pump
asp under drive
slp maf and flow pac setup
my question is will i be ok with the stock fuel system because this cam is much bigger than the old one and also i want to add spray after this i know i will need a fuel system for sure but can i run n/a on the stock stuff????
stock short block
fast90/90 (ported)
asp under drive
You've got alot of variables intake and exhaust wise.You really need to check the A/F ratio with the SLP Maf . That's my input, and that's for N/A. If you're going to spray look at the fuel pump and injector rate.
Hawk
Hawk
I'm was 430/430rwhp before my fast 90/90 install. My 28.8's were working at a little over 100%. Take it for what it's worth. I've also "heard" stock injectors are good to 460rwhp, but when it starts to take away from performance(about 400rwhp) it's time to upgrade. Just keep your eyes open and get a something in the range of an SVO30. I don't think you'll need anything higher than 38lbs right now. The SVO's will flow around 36-38 on our fuel pressure system
