Where can I find a fitting on the fuel rail?
Old 03-23-2006, 07:19 PM
ROCNDAV's Avatar
Default Where can I find a fitting on the fuel rail?
Where can I find a fitting like the one on the fuel rail?
I want to put one on the opposite corner (Right Rear) of the fuel rail for a mechanical fuel gauge that I will be mounting in the rear/cowel area.
If I found a bad/damamged fuel rail, can I simply unsolder/weld the cap and solder/weld the new one on? I take it the fuel rail is aluminum and would have to be welded (not soldered like copper pipe).
Old 03-23-2006, 08:13 PM
227Hawk's Avatar
The factory LSX fuel rails are steel so you can weld a steel -4AN fitting to the rails. If you have the room you can get steel compression fittings to
-4AN. ( The weld on take up alot less room.
Hawk
Old 03-23-2006, 11:28 PM
ROCNDAV's Avatar
Thanks
Old 03-27-2006, 10:48 PM
ROCNDAV's Avatar
Actually, I think only the brackets are steel. I tried sticking a magnet on the rails and caps and the magnet did not stick. The magnet only stuck to the brackets. Anyone know if the stock rails are aluminum?
Old 03-28-2006, 06:59 AM
227Hawk's Avatar
Actually were both wrong. The rails technically are'TIN' but you can tig weld steel fittings to them. I attached a pic for you look @ the cross-over.
Hawk
Old 03-30-2006, 11:18 AM
ROCNDAV's Avatar
Thanks Hawk.
