BIG HP guys inside. Question about fuel pressure..
So everyone with a custom fuel system are you boost referencing the fuel pressure regulator or just leaving it static??? Just wondering what to do with my new setup, set it at 61psi and reference or not...
I'd suggest..
it be referenced, in order to maintain delta P at 61psi.
Yeah, my main concern is the dual fuel tank system the vette has. It doesn't function at pressures below 58psi and if I reference it will be lower than that at idle. Right now set at 61psi the fuel pressure only drops to 58psi at WOT and stays there till redline...
