In Line Fuel pump?
In Line Fuel pump?
I new to this board but I heard if I have any questions I can ask on here. So here is the situation I am currently putting an STS turbo system on my car which is a 2001 Trans Am. I got the base model kit basically with the 60-1 Turbo and 42LB injectors and a moderate custom tune from Nelson performance. STS says that my stock fuel pump will keep up, But honestly I along with some of my mechanic friends dont believe them. SO i am looking for a good inline fuel pump or booster. I was just wondering if anyone has some experience with this system? My friend has the same system and has been running on 10LBS of boost with just the stock pump and has not come close to running lean, But I want to safe guard myself. I will only be running 5LBS. Any help on where to get a good inline pump and for reasonable price would be great. Thanks!
It would be a good idea to make an access hatch in your trunk to get to the intank pump.
Thanks alot for the input, so an access hatch is a good i dea its just getting enough courage to do that to my car..LOL. But if I decide to go with an inline what would you suggest as far as size and brand?
That is the same setup my friend has on his procharged 383 and he has no problems either he is the one who recomonded it. STS said I dont need one at 5LBS but i want to safe guard, Its like GM said I did not need a tranny cooler but I put one on just to be safe. How much did it run to get the inline walbro and where did you get it?
I dont have any experience with an inline pump, so I can only talk about my experiences with an intank pump.
The one i got was the Walbro 255lb/hr intank pump.
The inline Walbro pump ran me $150 for the kit. I purchased it at Speed Inc. Your in tank fuel pump will be fine with the boost you want to run. But if you decide to up the boost I would do a in tank. I have the 355 In tank pump and I am running 12 LBS of boost at WOT without problems. They are good pumps.
ok guys here is the deal. Speed inc did not even send me my whole kit for my inline pump. So will I be ok running 5LBS with just my stock pump without an in line pump with 42# injectors until I get the right kit? Thnks for the help
Originally Posted by blown 346
You should be fine with that amount of boost for now. I would call up Speed Inc and complain, and have thm send you the rest of your kit! I dont think they should have a problem with that.
