NEW Fuel systems added
I did some work on the old website last night I added a bunch of our complete fuel systems. I have several more and all can be had on the cheap/stealth with black pushlock style hose instead of the braided stainless line. A little cheaper and does not stand out as much. Check it out should help with deceiding on some fuel systems. http://www.nastyperformance.com/FuelSystems.html
Nate
Nate
Originally Posted by anarchy99
Nice setups and I like how you have it all laid out... No price on the stage 3 street kit though.
Nate
I just picked up the Stage I race kit recently only without fuel rails (for an LT1) and I can vouch that Nate researches these systems extensively and sends you everything you need for your install....
The only advice I can offer is to have your system mapped out as far as what exactly you'll need for fittings. Like where you'll need 180, 90 or 45 degree fittings and get those instead of the generic install fittings that Nate includes..... since they are the same price if you map everything out you won't be re-purchasing different fittings if you work that out with Nate beforehand...
I'm completely satisfied with my setup and since I went with a 10AN feed line I can just upgrade my pump and i'll be up to a Stage II Race kit with just that.....
yeah you gotta love the craftsmanship on this thing.... I loved installing it but too bad it's UNDER the car where nobody can drool over it..... I think I've windexed it about three times since I put it under my car to get the fingerprints off of it....
Nate
Nate
What would be great, and I know many would purchase this, is a -8 black pushlock line coming from an upgraded stock pump assembly from the tank to stock inline filter to a good set of fuel rails. Would that set up work for the big HP guys instead of installing a bulkhead fitting to -8 braided line? Say around 1000fwhp...
DJ's99SS- Here are some pics of the hose. For that kinda power you are going to want to upgrade the line coming out of the pump to -8 and the filter. I have the HP listed for what systems will handle what.
Ty- The fuel pump mounting bungs? I will get you them for $25
