upgrade for FI application
Old May 6, 2006 | 08:26 PM
ZL1Killa's Avatar
Default upgrade for FI application-fuel pump
I was going to buy the racetronix fuel system kit from thunderracing
part number 135-F99-FPKG2; i think its a good kit, just wondering on what others recommend/use...
Old May 7, 2006 | 04:46 PM
ZL1Killa's Avatar
what pump....ttt or fuel system upgrade people running...
Old May 10, 2006 | 12:10 PM
ZL1Killa's Avatar
Guys...for upgrading the fuel pump, being that my car is just getting an STS kit and motron 60#injectors and nothing race fancy
should i just get an in-line walbro fuel pump or should i upgrade and buy the whole kit that goes in the tank?
or do i just need to upgrade my injectors to the motron 60# and the stocker will be fine?
Old May 10, 2006 | 04:12 PM
ZL1Killa's Avatar
i know someone knows this stuff....
Old May 10, 2006 | 04:17 PM
Nasty N8's Avatar
What kinda power level are you looking to hit? I would deffinatly rec. the intank pump over an inline helper as that is a patch for a problem and you can not pull more fuel than the stock pump with feed.
Nate
Old May 10, 2006 | 09:07 PM
ZL1Killa's Avatar
around 500HP or so
what kit would you recommend, just the racetronix kit from thunderracing?
Old May 11, 2006 | 10:38 PM
ZL1Killa's Avatar
i'm just going to read everyone elses post about upgrading there fuel pumps... as i'm talking to myself....
Old May 12, 2006 | 05:42 AM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
you should be fine with the intank pump
Old May 12, 2006 | 11:10 AM
618HAWK's Avatar
The pump you listed should do you just fine. Just installed another one last weekend and it worked great for the person. He was over 500 @ the wheels.
I also run it and have no problems. Cant say more about that kit but it is the way to go for a plug and play system. Easy install! and Works Great!
As for your injectors Go with the Motoron 60,s Stockers will not cut it.
Old May 12, 2006 | 01:00 PM
ZL1Killa's Avatar
...yes THANKS GUYS!!
yeh the stockers already got replaced with 36.5#, hell should have gone bigger from the beginning with the motoron 60#ers
