Can i add a different brand pump to my fuel system?
I have a Walboro 255 intank pump... I was wondering if i can add a Bosch pump next to the maxed out single 255. The reason is that the bosch hold higher FP better than the walboro. Do you guys think this should work or help to sustain 74-76psi of FP at 14-15psi better than just adding another walboro?
Originally Posted by MIGHTYMOUSE
what bosch?
if you add any pump it will help... at your hp level you could probably still get away with an in line
The Bosch 420L intank pump. I would like to know if I can add it next to the 255 intank pump in the tank without a problem? I never heard anyone using two different intank pumps before? We are going to hot wire both of them to give them the highest voltage possible.
Or do you think its better to boost refrence the Bosch 420L pump whenever we boost move past 8psi its gets online?
Which way is easiest?
I dont think an inline would be enough. When it made 630rwhp we stopped the pull at 6K RPM and the HP was still climbing. The FP dropped from 62psi to 40psi at 6K RPM even though the Intank pump is hot wired. The limiter is set at 7K RPM so im expecting to see another 2psi or so and maybe 650rwhp on a Mustang Dyno if the stock bottom end holds up lol.
That would work it is a big pump to try and get into the tank. Another Walbro will get you to about 900hp with some other mods to the fuel system. lines, regulator, rails...
Nate
Nate
Nate
Nate
What do you think ?
you can make over 800rwhp with 2 255's and mototron 60's.
