fuel injectors...
fuel injectors...
I currently have RAcetronix 36.5#ers and they are soon not to be enough for what i'm going to be upgrading to. these racetronix also don't seem to like fuel swings quick, as they were causing my p1133 and p1153 codes
what would yall recommend? high impedence or low impedence?
i have heard a lot about the motron 60#ers, i heard you can install them and flash the car with the updated IFR and they are good to go and don't cause any problems
have you had any codes thrown from them not going to low enough switching for the 02s to switch rich to lean and lean to rich (its called proportional fueling in HPTuners)
i have racetronix right now 36.5#ers and they don't like going to a low enough point to where the computer likes to switch from lean to rich and rich to lean
(at least i think this is my problem, as WS6FirebirdTA00 had the same problem)
my question is has anyone had issues with the motron/siemens 60# injectors?
when you tune them you simply will need to change the IFR and they will be fine?
Originally Posted by ZL1Killa
?? ls1tech makes 42.5# injectors??
what in the hell? i'm confused as crap now.
I dont know if they make them but its on there site under there name.
are they disc type injectors?
and does LS1TEch.com sell there own injectors?.. thats pretty damn cool if they do
I think they do, I wrote to the pres of ls1tech and he kept refering them as there injectors so very vell could be there own.
