Are 44's too much
Old Mar 28, 2007 | 01:48 PM
3fourty6's Avatar
Default Are 44's too much
I'm in the process of installing the TSP's ms4 cam and their stage 1 ls6 heads. Along with all the bolt on's and ls6 intake. I'm thinking it should end up at around 450 hp. They claim that the stock fuel system can support up to 500 hp. Does anyone think this is correct? Doing the calculations I should get at least some 36 lb injectors but I found a really good deal on some 44's. So will the 44's be too much or will they be alright. I'm not sure if going a little bigger is bad or not. Thanks
Old Mar 28, 2007 | 02:43 PM
Frost's Avatar
I've never heard anyone say that it would support 500hp... 2000s had smaller injectors, the 01s, 02s usually make it to about 410-440 rwhp.
