Engine bogging. No codes It started this weekend. Did it 3 or 4 times. Pulling away in first gear it would bog down for a few seconds. Then it would run fine. Getting no codes so I'll rule out the maf and 02's. Could the fuel pump be going? It's a racetronix with only about 3K miles on it. |
have someone log your car and check to see if it is a fuel related issue |
no code doens't mena there isn't a problem with those parts. it's called an idiot light for a reason. |
Originally Posted by Psychopjv no code doens't mena there isn't a problem with those parts. it's called an idiot light for a reason. |
© 2024 MH Sub I, LLC dba Internet Brands
