200lb/hr Fuel Injectors
I remember a company made injectors that where larger then 160 lb/hr anyone know the name?
This is for a injected blown alcohol motor and 160/lb injectors at 90psi furl pressure are still coming up short.
i've not seen anything larger than a 160# personally. I'm sure that you allready know that you'r BSFC is up about 60% from a gasoline application. Realistically, to offer an option, look at adding a second set of injectors (depending on need)in a staged setup, if you've got a BS3. That might at least get you in the ball park.
Yeah i know that,
Bosch use to make 2000cc injectors but i can't find the PN.
@ 90 psi they would flow 3023cc/min
That would get me to where i need to be.
I am already using staged injection to be able to drive the car on the street for the power tour requirement.
28lb Primary Injectors for the drive
2000cc secondary for the alcohol and racing
