Racetronix plug n play harness
Hey a while back i bought a racetronix pump from a member on here. it was the plug and play kit RX-F99-FPWHG-2. My stock pump took a crap on me, so i installed this one and it runs great and has been running great for a couple months now. However, when i hooked the pump up, i just hooked the pump up and called it a day. I still have all the wiring in a bag in my room. My question is, do i really need to hook the wiring up? Are there any diagrams on how to do it? What will happen if i dont hook the wiring up? Also, i plan on running a 150 wet shot in the very very near future. How will not having the wiring affect that? Thanks!
The wiring just assures a stronger/cleaner voltage at the pump to keep your fuel pressure up. Yes it can be added later as it is plug & play. No there are no pics from racetronix's site. But I posted tons of pics from when I ran my wiring last month.
https://ls1tech.com/forums/fueling-injection/781014-my-racetronix-install-pics.html
LS1TECH Sponsor
Install the harness. This will pretty much eliminate the possibility of having problems with your factory wiring, relay and fuse center. Not to mention your pump is probably taking a 20%+ performance hit running off of the factory wiring.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
