Pump sits higher than sump(pic inside)what kind of problems and I gonna run into??
As you can see the pump sits higher than the sump..what kinda problems am I going to run into with this setup?
Pic is not showing? But, here's some tips:
Check with your pump manufacturer to see if your pump can lift; some can and others cannot.
If your pump can lift, it is still advisable to put a check valve in the outlet line (pressure side); that will keep the fuel from draining back and making the pump dry start.
