What size injectors on 408Ci N/A
Bad Trader Warning!
What size injectors on a 408 with Dart 225 heads and LS6 Intake/TB. I also have headers and exhaust. I have the stock fuel system now with 36Lb injectors. Is that ok or do I need a fuel pump and larger injectors.
http://www.rceng.com/technical.aspx?...DXxOIQ9THy9oOQ
these are the formulas to figure out injector size and HP limit of an injector. really easy to use.
good luck
good luck
