do i need injectors and fuel pump
i have aw bolts, t tex, 90/90 set up the factory fuel system ok, or do i need bigger injectors and fuel pump or will bigger injectors b ok
i would go bigger the way you sit right now and definately bigger if you are going to use any power adder.
I run a cam similar to the t-rex, with a 90/90, but i have tfs 215 heads. I run 36lb gm injectors which actually are close to 43@60psi. More than i will need N/A, but i also plan to spray also
