rear wheel bearing help
Old 01-05-2009, 05:09 PM
Badazz 97 TA's Avatar
Default rear wheel bearing help
so im replacing the rear wheel bearings and seals right now on my 10 bolt. i got one side out no problem and pounded it in. everything went fine. easier then i thought.
so i go to the other side and pound the old bearing out with a slide hammer. easy. i get everything setup to put the new one in and the little f8ker wont go in. same with the old bearing. i cant even get that one back in. i have the BFH mod but still nothing
will putting it in the freezer for a night help or what do i have to do?
Old 01-05-2009, 05:20 PM
ROCNDAV's Avatar
Are you sure you don't have any burrs on the axle tube? You might have to radius the edges a little bit.
Old 01-05-2009, 05:38 PM
no burrs that i can feel. i dont get how one side goes in no problem and i cant even get the other side started(new and old bearing.) stupid car!
Old 01-05-2009, 05:43 PM
ROCNDAV's Avatar
They did give you the right bearing? same number as the other (on the bearing itself, not on the box). Size it up against the old one that you took out. measure the O.D.'s with a caliper if you have one. Other than that, just make sure you are going straight in.
Old 01-05-2009, 06:27 PM
yeah its the same exact diameter and everything. like i said i cant even get the old bearing back in. so it must be a super tight fit on that side
heat expands metal and cold contracts it, correct?
Old 01-05-2009, 07:10 PM
ROCNDAV's Avatar
Yup. Try putting the bearing in a ziploc bag and stick it in the freezer.
Old 01-28-2009, 02:37 PM
jgarrick's Avatar
heat,,,,
Old 01-28-2009, 02:58 PM
madclown's Avatar
freeze the bearing and just before install heat the axle a little with a heat gun or carefully with a small propane troch.....
Old 01-28-2009, 07:09 PM
9000th01ss's Avatar
Find the problem.
You don't need to freeze or heat anything on these rears ever. And in a home freezer? LOL, come on. Thats maybe zero degrees?
When machine shops do this type of work they use liquid nitrogen which can freeze the parts down lower than -320. Thats approx 320 degrees lower than what your bearing is going to be.
Like I said, you never have to do this on these rears. Find the problem.
