ET streets and stock rearend? How many people are running ET streets on a stock rearend?? Would it go out very fast or what?thanx. -Brent |
Re: ET streets and stock rearend? i have seen some A4s at the track do ok with ET streets and then i have seen some M6sw blow the rear while on nittos. Its a gamble and depends on what stall converter you have. |
Re: ET streets and stock rearend? how bout a TCI 3600 2.5 STR and richmond 4.10's? with 26x10.50-16's? |
Re: ET streets and stock rearend? how bout a TCI 3600 2.5 STR and richmond 4.10's? with 26x10.50-16's? http://www.fbodycentral.com/forum/sh...;threadid=6446 You will see I have posted a reply in it describing my own sad tale. My converter is pretty mild at a 3200 stall and a 2.1 STR. My E.T. Streets are 26 x 11.5 x 16. Based on my own experience, I would say you're living on the edge. |
Re: ET streets and stock rearend? I was able to get away with it. But like Ed said. Your living on the edge. |
Re: ET streets and stock rearend? I most cases, it is not the ET's that take the rear out but wheel hop. Common mistake is to slap ET's on stock suspention. Some Polyurethane bushings, PH,LCAs and TA's will help the life of the'10' a lot. Of course the higher you stall the higher the risk. |
Re: ET streets and stock rearend? I recently ran my white 99 T/A. While the 10-bolts are pretty weak in the long run, mine proved to be worthy. The car has 52,000 miles and the only mods iclude the TR 224/224 .565/.563 112 LSA cam, Spec S3, and Mac midlength headers w/x-pipe, bullets, and turndowns. Stock suspension/components, 3550 lbs.w/driver, 26x10 stickies and a dry 100 shot-all on the measley little 10 bolt. the car went 11.35 @ 122.78 w/1.56 60'. Hard to believe? Well believe it, and the rear end is in dandy shape. I'd like to see what the best 60' on stock rear is, so please reply. Jake(friend of ggr12) 99 M6 T/A(white) :eek2: |
Re: ET streets and stock rearend? I have made a few passes on Hoosier Drags and no problems so far. |
Re: ET streets and stock rearend? I've had over 20 passes with ET's and no problem so far. 3000rpm launches. but I repaced rear stock rubber with poly bushings + one air bag in right rear. |
© 2024 MH Sub I, LLC dba Internet Brands
