aluminum driveshaft?
Old 02-20-2009, 06:33 AM
Daredevil_TA's Avatar
Default aluminum driveshaft?
So i was doing some research the other day an came across something, So were there some f-body's that came stock with aluminum driveshafts? an if so which ones? is there an RPO code or anything that tells you?
Old 02-20-2009, 10:16 AM
slayer_taunu's Avatar
dont quote me on this, but i'm pretty sure all LS1 f-bodies have aluminum driveshafts unless you had 2.73 gears.
Old 02-20-2009, 10:19 AM
Dave 96TA's Avatar
Most LT1 F-bodies came with a steel driveshaft. Most LS1 F-bodies came with aluminum.
Old 02-20-2009, 10:27 PM
01ssreda4's Avatar
i believe thats correct, and only autos came with 2.73s
Old 02-21-2009, 08:22 PM
red02Hawk's Avatar
my 99 m6 camaro came with a steel drive shaft, but the 02 m6 hawk i had came with an aluminum one, how's that for your logic? lol
Old 02-22-2009, 02:28 AM
01ssreda4's Avatar
^^^maybe somebody swapped it out before you got the car
Old 02-22-2009, 02:31 AM
R1ch's Avatar
My 01 SS has an aluminum one.
Old 02-23-2009, 08:16 AM
just look under the car. if the DS is spotless, its aluminum. if it has some rust on it, its steel. how's that for logic?
Old 02-23-2009, 10:49 AM
Elliott's94Z's Avatar
LS1 based models : Aluminum
LT1 based : Steel DS
Old 02-23-2009, 10:57 AM
SS101's Avatar
ive got a steel one...i also have an a4 with 2.73s
Old 02-23-2009, 11:02 AM
The aluminum ones tend to break more so over the steel. I've got my steel one hanging around for back up. I have seen several post/threads on here lately about guys snapping their aluminum DS. As far as your 2.73's go you need to ditch em' and bump it up in gear
Old 02-23-2009, 02:34 PM
SS101's Avatar
yeah i'm getting 3.73s in my 12-bolt!!!
but as far as the Al vs. steel shafts, the steel ones tend to vibrate so badly that they take out tranny tail housings at high rpms, hence the 3.23 and 3.42 cars got aluminum. but as someone said, just take a quick peak under your car: silver looking = Al, rusty and brown = steel
