ls1 brakes on lt1 moser
im pulling my moser 9in out of my 97 and putting it in my 99.can i bolt the ls calipers on the lt brackets without any issues?i dont want to have to pull both rears apart if not needed.thanks,joe
If I remember correctly the backing plates are different. You'll have to slide the axles out and remove then re-press the bearings on the axles. The backing plates are what hold the axles in if I remember correctly.
-Dustin-
-Dustin-
