What driveshaft with the Moser 9"?
Restricted User
what drive are yall using with your Moser 9"? will the stocker just bolt up? i know it has a 1350 yoke but i dont know how much it differs from the stock driveshaft. any recommendations on where to get one?
I was running a PST aluminum 3.5 replacement for my stock driveshaft when I put my moser 9 in. The driveshaft stuck out of the tranny more (abt 1 inch) after the install as compared to the stock set up. The stock length still worked and the u joint fit. I would prefer a little more yolk in the tranny, but I am still within recommendations.
LS1Tech Premium Sponsor
the stock driveshaft will work with a 447 conversion u-joint, but it will be a bit short. the 9 inch is a little shorter than the GM 10 bolt, nad the pinion is lower from centerline, thus pulling the shaft out of the trans. the Strange 3 inch chromemoly shaft is the best bang for the buck by far. will come balanced and assembled, ready to install. I have all the correct dimensions for the trans/rearend combos. pm me for a quote.
