Moser 12bolt
Old 11-03-2003, 05:09 PM
B-MAN's Avatar
Angry Moser 12bolt
I have a moser 12 bolt that is constantly leaking differential fluid out of the breather valve. Is there any cure for this
thanks
Old 11-03-2003, 05:19 PM
SPANKY LS1's Avatar
Put a ~12" piece of vaccumm hose on it, and zip-tie it to your upper PHB, and no more leaks.
Old 11-04-2003, 11:04 AM
B-MAN's Avatar
Thanks for the tip, I already had a hose on it, but it was only abou5-6 inches long. I will try a 12" next.
Thanks
Old 11-04-2003, 11:29 AM
Hawkn01's Avatar
Thanks
Make sure you don't have too much fluid in the rear end, sounds like what the problem is !!
Old 11-04-2003, 11:58 AM
gator's 99TA's Avatar
agreed, it sounds like too much rear end fluid. it leaks out the breather hole till it isnt too full. happened to mine. now it never leaks since i put in the correct fluid level.
Old 11-04-2003, 12:41 PM
8 second mod
Noyzee's Avatar
This was my outlook as well. Any idear on exactly how much they take?
3 qt's?
