'94 4 channel rear in a '02 camaro, problems?
as far as i know, there were no 4-channel rears in '94...
1995 was the 1st yr that traction control was introduced as an option for the f-body cars. i say this because i had a '95 z28 that had it...
might check to make sure of the exact yr of the 10-bolt youre looking at: 3-channel are ABS, 4-channel are ABS/ASR (trac control)...
as for bolting in, yes, i believe the backing plates were different and need to be swapped bacuse of the LS1 going to larger and better brakes...
