8.8 guys.. how did you get abc/tcs to work?
Old 06-24-2009, 03:44 PM
Ironxcross's Avatar
Default 8.8 guys.. how did you get abc/tcs to work?
I'm looking into building my own rear, but I don't have a solution to this issue just yet.. Any ideas?
Old 06-24-2009, 09:59 PM
98silvertacrbn's Avatar
3 channel or 4 channel? On the 94 to 98 mustang rears i think you can use the reluctor wheels and sensors from the mustang axles just wire the sensors to your car that it is if it's 4 channel. I don't know how to get a three channel to work unless it's a explorer 8.8 i think it has sensor on the third member reluctor wheel is on the carrier,but the pinion is offset 2-3/4" witch wont work in a f-body. I am building a 8.8 for my car out of a 94 cobra i am going to weld f-body brackets on i don't know if i am going to use a 4-link or weld a torque arm on to the housing. Good thing about using 94-98 rears are they are 2" shorter on each side then a 10 bolt and i'm just going to re drill the axle to Chevy pattern
Old 06-25-2009, 01:00 AM
Ironxcross's Avatar
I'm thinking of having the housing constructed for me, and them I'll assemble the components. It's a 4 channel car.. I'm not even sure where to begin with the traction control and abs systems on this car.
Old 06-27-2009, 08:56 PM
Ironxcross's Avatar
no one has any insight on this?
