Anyway To Build A Strong 10 Bolt??
Old 06-27-2009, 02:29 PM
19BLACKBIRD99's Avatar
Default Anyway To Build A Strong 10 Bolt??
Any suggestions??
Old 06-27-2009, 04:15 PM
Black 99 Bird's Avatar
I would save for a 12 bolt or 9". But to answer your question, T/A cover and weld the axle tubes. Moser also makes hardened axles for our cars.
Old 06-27-2009, 04:16 PM
scrapmetal's Avatar
http://www.moserengineering.com/
Old 06-27-2009, 09:01 PM
smokinponcho73's Avatar
eaton posi is a great diff. I am pushing almost 500 hp to the ground through mine and it hasnt broke I dont launch hard and use only street tires but it seem's tough.
Old 06-29-2009, 10:09 AM
omcar's Avatar
Default rears
I broke 2 Eaton posi's in 3 years..now have an Auburn pro series, moser axles and Richmond gears..... Seems fine.
Old 06-29-2009, 10:18 AM
Ima try and build mine up instead of buyin a new rearend
Old 06-29-2009, 10:36 AM
tee-boy's Avatar
weld the axles (really good) to the spider.
Old 06-29-2009, 11:09 AM
omcar's Avatar
I've been racing mine for 9 years and only broke a couple of posi's..cheaper than a 12/9 bolt. IF I had a stick car I would save for a 12/9 bolt for sure.
Old 06-29-2009, 02:30 PM
bracketracerZ28's Avatar
busted 3 gear sets in 2 years. I have the 3.37 yukon gears now and they are handling track duty so far.
Old 06-29-2009, 02:31 PM
sorry, 3.73 gears
Old 06-29-2009, 05:38 PM
yeah you said 3.37 I was whattt lol
but I knew what you meant after a second glance
Old 07-22-2009, 04:36 AM
MattysTA's Avatar
there is also a company making an axle tube brace kit for the 10bolts now. im going to be getting it soon once i get my old rear back with the 3:73s and t/a cover. then ill have my buddy weld up the tubes also...
Old 07-22-2009, 10:01 AM
john563's Avatar
got a link? let us know how it holds..I may be interested
Old 07-22-2009, 03:40 PM
01ssreda4's Avatar
kinda interested when welding tubes do they have to be held in a jig of sorts to keep them from deflecting bc of the welding heat?
Old 07-22-2009, 04:22 PM
Redlinez's Avatar
This has been dreamed about for years. It's physically impossible to make a 7.5" ring gear 10 bolt strong. Midwest Chassis has one of the most affordable custom tailored rear ends you'll find. The good news is there are plenty of cheap 10 bolts for sale.....
Old 07-22-2009, 07:45 PM
Nubbz33's Avatar
Weld the axle tubes to the center section, t/a cover, richmond gears, good center or spool, moser axles, billet yoke, and im surprised no one has said to get c-clip eliminators. Get rid of the c-clips.
Old 07-24-2009, 08:02 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Originally Posted by 19BLACKBIRD99
Any suggestions??
Yes.
Don't Race it.
Leave the Automatic in.
Save your pennies for something better.
The amount of $$$ spent strengthening a 10 bolt is a good shot toward a 12 bolt or modified Ford 8.8.
Old 07-24-2009, 08:25 AM
JonatRLMS's Avatar
Originally Posted by BlackScreaminMachine
Yes.
Don't Race it.
i have to agree here. not saying its a total waste, but well, there are so many better options
Old 07-24-2009, 09:54 AM
Moderator
jimmyblue's Avatar
"Stronger", yes. "Strong enough", you already got the advice.
The more you go up in gear ratio, the more grief you put on
the axles, the Torsen chunk and the fewer gear teeth meshed
to share the load.
Old 07-24-2009, 05:12 PM
SLawson86's Avatar
the best way i have seen to save a 7.5, go with the suggestions above, and diet. the ones who take sh*t tons of weight out of the car seem to last forever. just my .02
Quick Reply: Anyway To Build A Strong 10 Bolt??
