Build or buy 9inch
Build or buy 9inch
I noticed some of the sites sell the housing for these with axles. Havent found all the other parts. Is it cheaper to build the 9 with new parts or to just spend the 2300 and get it done?
Setting the gears up on a 9inch? Same as a gm 12. Have built a few 10 bolts and few 12's but never a 9.
thanks
thanks
http://www.exoticperformanceplus.com...html?item=1116
We sell the Moser housing/axle package for $1050 shipped, which is a great deal. People will go out and pick up a used third member to install, if you do, make sure you get one that has an N on it. The n means it is the stronger nodular iron unit, normally found in the Ford pick up trucks and higher performance Ford musclecars. The standard Ford third member may end up with you having carnage on the starting line at your local dragstrip. Bob
I noticed it on your site. What if I bought it all new from you and did 100% assembly. Gears and everything, price? I want a spool in it.
Would I just be buying the case? and then put the gears/spool in it if I got the third member. How do you tell the difference N, where is it? Pic mayby
This would be the best way for you to go. Free shipping too!
http://www.exoticperformanceplus.com...html?item=1263 Here is a copy of the installation instructions. Bob
I know how to put them in etc. I dont mind building the 3rd member and setting up the gears. I would actually prefer it if I did the gears, 0 for 5 with 12 bolts that had gear whine from the factory.
I want to get the housing, buy the third member(case). Put a spool and gear in it then put it in the housing. I really would like to build one for 2k. Is that even possible or am dreaming?
Thanks for the help its gotten you a customer when the time is right.
