Rear assembly help please
Ok I pulled my axles out. i went to put them in, now you got the two spider gears the axles go into, then you have 2 spider gears on top and bottom. when I went to put my axle in it somehow made the top and bottom spider gears fall out, and I for the life of me can't figure out how to get them all back in, can somebody show me how or give me some tips please.
Put one on each side of the carrier and rotate them back in with the the axle. There might be some shims that go between the carrier and the gears. Those have to go in first as there is a lip on them that fit into the carrier hole that the pin goes thru. It's kind of a pain, but when you do one, the rest come easy.
