Weight difference between a tru-trac and a spool
Does anyone know the weight difference between a tru-trac and a spool. I bought a 12 bolt from Strange and I am pretty sure it has a tru-trac in it. Is that standard in those rear ends. I am going to change the gears and I want to drop some weight too. I put a tru trac in my 07 silverado and remember it being heavy but I didnt weigh it.
i did the swap when i still had my camaro. i had a 9" in it. i know i posted it a while back i think in the rear end weights
found it. saves 8lbs
https://ls1tech.com/forums/gears-axl...-you-have.html
Here is my brother's info from going from an Eaton posi to an alum spool. Link to car.
http://www.exoticperformanceplus.com...tCar.php?car=7 Bob
Eaton posi and carrier bearings= 24.995
Moser aluminum spool and carrier bearings= 6.56
Total savings going to spool= -18.44
I saved 32#s with my s60 the truetrac is huge on them. (steel strange spool)
https://ls1tech.com/forums/drag-raci...-truecrap.html
