whats bad? carrier, ring & pinion or bearings?
Old 01-22-2010, 05:29 PM
jdhedman's Avatar
Default whats bad? carrier, ring & pinion or bearings?
ok my rear end is going I think. and I want to get it fixed until I can get my S60 like the big boys so here is my Question
ok so I have a Torsen (mechanical) lsd witch i know are the weaker of the two options. and I have 3.42 gears.
I am getting slap when I get back on the gas after coasting and when I had the car up in the air I could feel some slack in the drive train when turning the wheel forward and back.
So my question is how can I tell what is it that is bad. the carrier, ring and pinion gears or some bearings.
Old 01-25-2010, 06:38 AM
cambirdracing's Avatar
That slack is pretty much normal. Does it make any noise?
Old 01-27-2010, 12:02 AM
94camaroz28lt1's Avatar
Is my rear ok? I just did the pinion seal, I marked the nut and put it back to exalt where it was. I added 70W 90 synthetic, and drove it for almost 300 miles, I heard it winning in 6th gear, and while coasting. I found out this is the wrong fluid so I then drained and refilled with 80W 90 and Gm limited slip addictive. It still hums/wines when in 6th gear going 55 60 miles an hour, or while coasting in 3rd 4th 5th 6th, If i accelerate it goes away. It is a vrery quite hum, and if the radio is on I don't even hear it. Is this normal am I just periniod?
Old 01-27-2010, 06:20 AM
You shouldn't need to additive in the Torsen. That's only for clutch type rears, probably won't hurt thou. You probably have a pinion bearing going bad.
Old 01-31-2010, 04:28 PM
mmmmm. that sucks, what will happen if I leave it for now?
Old 01-31-2010, 04:29 PM
did I make the nut to tight or something?
Quick Reply: whats bad? carrier, ring & pinion or bearings?
