9 inch center section is this a good deal im looking to buy this and Im just trying to do my research before I do... i have a complete 2.89 carrier with 3.50 gears, and a 28 spline mini spool. 28 spline support bearing with yoke. need to be set up and i would replace the races on the spool..it has been sitting around for a few years in storage,,,,,,,,i want 100 bucks. and dose it look like this gear set will work?? http://www.summitracing.com/parts/SUM-740903/ |
no one? |
link not working. Let me know if we can help Thanks, Mark |
links fixed |
no one builds there own center sections?? |
i see you have an M6 eh? you should get some 4.30's instead! |
I'm putting together a somewhat budget center right now. Few things to look out for: Carrier bearing size and what type of pinion suport you have. Those will determine what rebuild kits you need. |
Originally Posted by daryn c
(Post 12817325)
Originally Posted by 97camaross
(Post 12821067)
that would put me past red line in fourth in the 1/4 mile |
Originally Posted by Duffster
(Post 12826486)
Or let you bounce on redline for about 50 feet |
Have fun shifting then, because you can't press in the clutch, shift the gear to 5th and let out of the clutch in that same 50 feet.... 3-4, possibly, 4-5... nope and that same time you're pressing in on the clutch, you're loosing acceleration... momentum is then your only friend... |
^^^^ are you takling about me b/c the other guy is talking about 4.30s which im not getting i am getting 4.10s |
© 2024 MH Sub I, LLC dba Internet Brands
