What's Stronger??? What's stronger (as in less common to brake) a series 2 career ring and pinion or series 3 career ring and pinion? Example: series 2 4.10 -vs series 3 4.10 Witch will brake 1st? |
Should be no difference,pinions are the same,ring gear teeth are the same,only difference is the amount of material under ring gear teeth to make up for the difference in offset. http://i258.photobucket.com/albums/h...luesflatCS.jpg |
ok thanks |
| All times are GMT -5. The time now is 12:00 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
